Virtuelle Benutzer und Domains mit Postfix, Courier und MySQL (Debian Etch)
Danach erstellen wir das SSL Zertifikat, das für TLS benötigt wird:
cd /etc/postfix
openssl req -new -outform PEM -out smtpd.cert -newkey rsa:2048 -nodes -keyout smtpd.key -keyform PEM -days 365 -x509
<– Enter your Country Name (e.g., „DE“).
<– Enter your State or Province Name.
<– Enter your City.
<– Enter your Organization Name (e.g., the name of your company).
<– Enter your Organizational Unit Name (e.g. „IT Department“).
<– Enter the Fully Qualified Domain Name of the system (e.g. „server1.example.com“).
<– Enter your Email Address.
Ändere dann die Berechtigungen des smtpd.key:
chmod o= /etc/postfix/smtpd.key
6 Konfiguration von Saslauthd
Führe zuerst dies aus
mkdir -p /var/spool/postfix/var/run/saslauthd
Bearbeite dann /etc/default/saslauthd. Setze START auf yes und ändere die Zeile OPTIONS=“-c“ zu OPTIONS=“-c -m /var/spool/postfix/var/run/saslauthd -r“:
vi /etc/default/saslauthd
# Settings for saslauthd daemon
# Should saslauthd run automatically on startup? (default: no)
START=yes
# Which authentication mechanisms should saslauthd use? (default: pam)
# Available options in this Debian package:
# getpwent  -- use the getpwent() library function
# kerberos5 -- use Kerberos 5
# pam       -- use PAM
# rimap     -- use a remote IMAP server
# shadow    -- use the local shadow password file
# sasldb    -- use the local sasldb database file
# ldap      -- use LDAP (configuration is in /etc/saslauthd.conf)
# Only one option may be used at a time. See the saslauthd man page
# for more information.
# Example: MECHANISMS="pam"
MECHANISMS="pam"
# Additional options for this mechanism. (default: none)
# See the saslauthd man page for information about mech-specific options.
MECH_OPTIONS=""
# How many saslauthd processes should we run? (default: 5)
# A value of 0 will fork a new process for each connection.
THREADS=5
# Other options (default: -c)
# See the saslauthd man page for information about these options.
# Example for postfix users: "-c -m /var/spool/postfix/var/run/saslauthd"
# Note: See /usr/share/doc/sasl2-bin/README.Debian
OPTIONS="-c -m /var/spool/postfix/var/run/saslauthd -r"
Erstelle dann die Datei /etc/pam.d/smtp. Sie sollte lediglich die beiden folgenden Zeilen beinhalten (pass auf, dass Du die richtigen Datenbank Angaben eingibst):
vi /etc/pam.d/smtp
auth    required   pam_mysql.so user=mail_admin passwd=mail_admin_password host=127.0.0.1 db=mail table=users usercolumn=email passwdcolumn=password crypt=1
account sufficient pam_mysql.so user=mail_admin passwd=mail_admin_password host=127.0.0.1 db=mail table=users usercolumn=email passwdcolumn=password crypt=1
Erstelle als Nächstes die Datei /etc/postfix/sasl/smtpd.conf. So sollte sie aussehen:
vi /etc/postfix/sasl/smtpd.conf
pwcheck_method: saslauthd
mech_list: plain login
allow_plaintext: true
auxprop_plugin: mysql
sql_hostnames: 127.0.0.1
sql_user: mail_admin
sql_passwd: mail_admin_password
sql_database: mail
sql_select: select password from users where email = '%u'
Starte dann Postfix und Saslauthd neu:
/etc/init.d/postfix restart
/etc/init.d/saslauthd restart
7 Konfiguration von Courier
Nun müssen wir Courier mitteilen, dass es sich gegenüber unserer MySQL Datenbank authentifizieren soll. Bearbeite zunächst /etc/courier/authdaemonrc und ändere den Wert von authmodulelist so dass es heißt:
vi /etc/courier/authdaemonrc
authmodulelist="authmysql"
Nimm dann ein Backup von /etc/courier/authmysqlrc vor und leere die alte Datei:
cp /etc/courier/authmysqlrc /etc/courier/authmysqlrc_orig
cat /dev/null > /etc/courier/authmysqlrc
Öffne dann /etc/courier/authmysqlrc und füge folgende Zeilen ein:
vi /etc/courier/authmysqlrc
MYSQL_SERVER localhost
MYSQL_USERNAME mail_admin
MYSQL_PASSWORD mail_admin_password
MYSQL_PORT 0
MYSQL_DATABASE mail
MYSQL_USER_TABLE users
MYSQL_CRYPT_PWFIELD password
#MYSQL_CLEAR_PWFIELD password
MYSQL_UID_FIELD 5000
MYSQL_GID_FIELD 5000
MYSQL_LOGIN_FIELD email
MYSQL_HOME_FIELD "/home/vmail"
MYSQL_MAILDIR_FIELD CONCAT(SUBSTRING_INDEX(email,'@',-1),'/',SUBSTRING_INDEX(email,'@',1),'/')
#MYSQL_NAME_FIELD
MYSQL_QUOTA_FIELD quota
Starte Courier dann neu:
/etc/init.d/courier-authdaemon restart
/etc/init.d/courier-imap restart
/etc/init.d/courier-imap-ssl restart
/etc/init.d/courier-pop restart
/etc/init.d/courier-pop-ssl restart
Indem Du dies ausführst
telnet localhost pop3
siehst Du, ob Dein POP3 Server richtig funktioniert. Er sollte +OK Hello there zurück geben. (Gib quit ein um zurück zur Linux Kommandozeile zu gelangen.)
server1:/etc/postfix# telnet localhost pop3
Trying 127.0.0.1…
Connected to localhost.localdomain.
Escape character is ‚^]‘.
+OK Hello there.
quit
+OK Better luck next time.
8 Bearbeite /etc/aliases
Nun sollten wir /etc/aliases öffnen. Pass auf, dass postmaster auf Root und Root auf Deinen eigenen Benutzernamen oder Deine E-Mail Adresse gerichtet ist, z.B. wie folgt:
vi /etc/aliases
postmaster: root
root: postmaster@yourdomain.tld
Immer wenn Du /etc/aliases modifizierst, musst Du danach dies
newaliases
ausführen und Postfix neu starten:
9 Installation von amavisd-new, SpamAssassin, And ClamAV
Um amavisd-new, spamassassin und clamav zu installieren, führe folgenden Befehl aus:
apt-get install amavisd-new spamassassin clamav clamav-daemon zoo unzip bzip2 unzoo libnet-ph-perl libnet-snpp-perl libnet-telnet-perl nomarch lzop pax
Danach müssen wir amavisd-new konfigurieren. Die Konfiguration ist auf verschiedene Dateien aufgesplittet, die sich im /etc/amavis/conf.d Verzeichnis befinden. Sieh Dir jede einzelne an um Dich mit der Konfiguration vertraut zu machen. Die meisten Einstellungen sind in Ordnung, bis auf diese drei Dateien, die wir modifizieren müssen:
Zuerst müssen wir ClamAV und SpamAssassin in /etc/amavis/conf.d/15-content_filter_mode aktivieren, indem wir die @bypass_virus_checks_maps und die @bypass_spam_checks_maps Zeile aktivieren:
vi /etc/amavis/conf.d/15-content_filter_mode
Die Datei sollte wie folgt aussehen:
use strict;
# You can modify this file to re-enable SPAM checking through spamassassin
# and to re-enable antivirus checking.
# Default antivirus checking mode
# Uncomment the two lines below to enable it back
@bypass_virus_checks_maps = (
   %bypass_virus_checks, @bypass_virus_checks_acl, $bypass_virus_checks_re);
# Default SPAM checking mode
@bypass_spam_checks_maps = (
   %bypass_spam_checks, @bypass_spam_checks_acl, $bypass_spam_checks_re);
1;  # insure a defined return
Dann solltest Du Dir die Spam Einstellungen und die Aktionen für Spam-/Virus-Mails in /etc/amavis/conf.d/20-debian_defaults ansehen. Wenn die Standard Einstellungen für Dich ok sind, dann brauchst Du nichts ändern. Die Datei enthält viele Erklärungen, d.h. ich muss die Einstellungen hier nicht erklären:
vi /etc/amavis/conf.d/20-debian_defaults
$QUARANTINEDIR = "$MYHOME/virusmails";
$log_recip_templ = undef;    # disable by-recipient level-0 log entries
$DO_SYSLOG = 1;              # log via syslogd (preferred)
$syslog_ident = 'amavis';    # syslog ident tag, prepended to all messages
$syslog_facility = 'mail';
$syslog_priority = 'debug';  # switch to info to drop debug output, etc
$enable_db = 1;              # enable use of BerkeleyDB/libdb (SNMP and nanny)
$enable_global_cache = 1;    # enable use of libdb-based cache if $enable_db=1
$inet_socket_port = 10024;   # default listenting socket
$sa_spam_subject_tag = '***SPAM*** ';
$sa_tag_level_deflt  = 2.0;  # add spam info headers if at, or above that level
$sa_tag2_level_deflt = 6.31; # add 'spam detected' headers at that level
$sa_kill_level_deflt = 6.31; # triggers spam evasive actions
$sa_dsn_cutoff_level = 10;   # spam level beyond which a DSN is not sent
$sa_mail_body_size_limit = 200*1024; # don't waste time on SA if mail is larger
$sa_local_tests_only = 0;    # only tests which do not require internet access?
$final_virus_destiny      = D_DISCARD;  # (data not lost, see virus quarantine)
$final_banned_destiny     = D_BOUNCE;   # D_REJECT when front-end MTA
$final_spam_destiny       = D_BOUNCE;
$final_bad_header_destiny = D_PASS;     # False-positive prone (for spam)
Bearbeite schließlich /etc/amavis/conf.d/50-user und füge die Zeile $pax=’pax‘; in der Mitte ein:
vi /etc/amavis/conf.d/50-user
use strict;
# Place your configuration directives here.  They will override those in
# earlier files.
# See /usr/share/doc/amavisd-new/ for documentation and examples of
# the directives you can use in this file
$pax='pax';
#------------ Do not modify anything below this line -------------
Führe danach diese Befehle aus um den clamav Benutzer der amavis Gruppe hinzuzufügen und amavisd-new und ClamAV neu zu starten:
adduser clamav amavis
/etc/init.d/amavis restart
/etc/init.d/clamav-daemon restart
/etc/init.d/clamav-freshclam restart
Nun müssen wir Postfix so konfigurieren, dass eingehende E-Mails durch amavisd-new geleitet werden:
postconf -e ‚content_filter = amavis:[127.0.0.1]:10024‘
postconf -e ‚receive_override_options = no_address_mappings‘
